07 Yukon - New Member
claustralia
Hey everyone, been a lurking for a while, figured I'd post my recent Yukon buy and work I've done so far. 07 5.3 SLT with 300k miles :O. It had a new engine dropped in around 250k and I had the transmission rebuilt due to slipping after my purchase. Mainly my kid carrier but would like to make it last as long as possible. I've had an 01 Sierra for the last 20 years, which I kept, but figured I'd try my luck on the GMT900s (wife likes the body style more). Needless to say, I've done quite a bit to revive it and kept track of every purchase. Here is the long list:
Rebuilt Transmission
VXDIAG VCX Nano GDS2 and Tech2WinAmazonScanner Tool
GM GENUINE 15881861RockAutoBuzzing Sound Rear A/C Control
DORMAN 25828RockAutoBroken window Scraper Seal
STABILUS 3B807349RockAutoLiftgate Lift; Right
STABILUS 3B242389RockAutoLiftgate Lift; Left
STABILUS 4B047123RockAutoBack Glass Lift; Left
STABILUS 4B045928RockAutoBack Glass Lift; Right
ACDELCO CF193C GM Original Equipment; Carbon Cabin Air FilterRockAutoCabin Air Filter Replace
ACDELCO 1581644RockAutoBlower Motor
Edelmann 80617AmazonPower Steering High Pressure Hose
EDELMANN 80702RockAutoPower Steering Low Pressure hose cooler to reservoir
EDELMANN 80618RockAutoPower Steering Low Pressure hose gear to cooler
DORMAN 924716RockAutoIgnition Lock Cylinder
SHEE-MAR SM1520RockAutoFront Right Latch and Actuator Assembly
SKP SK931303RockAutoFront Left Latch and Actuator Assembly
SKP SK931108RockAutoRear Left Latch and Actuator Assembly
SKP SK931109RockAutoRear Right Latch and Actuator Assembly
GM GENUINE 22834330RockAutoCabin Air Temp Sensor Front/Rear
GM GENUINE 15947841RockAutoDIC Display Buttons
SKP SK901159RockAutoLiftgate Window Release Button
GM GENUINE 20983936 (x2)RockAuto12v Outlet Cover
GM GENUINE 84356647RockAutoFront ABS Wheel Speed Sensor
TRICO 13220 Ultra; Beam StyleRockAutoFront Wipers x2
ACDELCO 25820122 GM Original EquipmentRockAutoRear Wiper
Door Locking Rod Knob - GM (15844617)GM Parts Direct4x Door Lock Knobs
Driver Side Front Door Weatherstrip - GM (22766409)GM Parts DirectReplace Driver Side Door Seal
2020 Style GM Key Fob RetrofitBoostAutoPartsReplace Key Fob
Amsoil Power SteeringAmsoil16 oz x 8 (4 qts) for flush/bleed
Gruven Folding Mirror AssemblyGruven Fix side mirror gears
GM GENUINE 15798935RockAutoRear Wiper End Cap
Battery Terminal TightenerAmazonBattery Terminal
ACDelco GM Original Equipment 22759208AmazonCabin Air Filter Conversion
DORMAN 911064RockAutoVapor Canister Vent Valve / Solenoid
GM GENUINE 215464RockAutoVapor Canister
PRECISION DWB111007RockAutoRear Door Weatherstrip Seal
Dorman 959-003AmazonDriver Side Door Mirror Cover, Chrome
Exterior Chrome Door Handle Rear Right Passenger SideAmazonExterior Chrome Door Handle Rear Right Passenger Side
GM GENUINE 13498958RockAutoHeadlamp Light Sensor
GM GENUINE 84370714RockAutoUpper Intermediate Steering Shaft
Front Driver Exterior Door Handle ReplacementAmazonFront Driver Exterior Door Handle Replacement
SYLVANIA - Headlight Restoration KitAmazonHeadlight Restore
GM Genuine Parts 25815601AmazonSteering Shaft Boot Seal
ACDelco GM Original Equipment 214-1680AmazonEVAP Purge Valve
ACDelco GM Original Equipment GT295 AmazonFuel Tank Filler Cap
Denali Grille Denali Upper OEMEbayDenali Grille Denali Upper OEM
LEFT QUARTER PANEL HATCH GATE TRIM APPLIQUE OEMEbayLEFT QUARTER PANEL APPLIQUE OEM
19121538 Seat Belt Buckle EndEbay19121538 Seat Belt Buckle End
15816854 VALVE,BK BODY OPG FRM PRESS RLFGM Parts GiantRear Cabin Pressure Vents x2
DiabloSport 8245 inTune I3 Platinum Programmer 01-10 6.6L GM DuramaxJB ToolsDiablo Sport Tuner
Diablew TuneDiablewCustom Tune
J-42640Freedom RacingSteering Column Lock
Third Row SeatsCraigslistThird Row Seats
Seat CoversEbaySeat Covers
Seat FoamSeat ShopSeat Foarm
Left Air VentEbayLeft Air Vent
ACDelco GM Original Equipment A3181CAmazonAir Filter
Top Air Vent CoverAmazonDorman 926-336
GM GENUINE 19178561RockAuto2x Inner Tie Rod
MEVOTECH TXMS506116RockAuto2x Outer Tie Rod
MEVOTECH CTXK80669RockAutoFront Left Upper Control Arm
MEVOTECH CTXK80670RockAutoFront Right Upper Control Arm
MEVOTECH CTXMS50152RockAutoFront Left Lower Control Arm
MEVOTECH CTXMS50153RockAutoFront Right Lower Control Arm
MEVOTECH TXMS50820RockAutoSway Bar Link
MONROE 139104 x2RockAutoFront Shock/Strut Coil Assembly
GM GENUINE 15124516 x2RockAutoSway Bar Bushings
Replacement Gears for Seat TIltTwoMen1GarageReplacement Gears for Seat TIlt
MEVOTECH H515097RockAuto2 x Front Whell Hub Bearing Assembly
WAGNER OEX1092RockAutoFront Brake Pads
RAYBESTOS 580279FZNAmazonFront Brake Rotors
Raybestos FRC11713NAmazonFront Right Caliper
Raybestos FRC11714NAmazonFront Left Caliper
GM Genuine Parts 176-2003AmazonFront passenger brake hose
GM Genuine Parts 176-2002AmazonFront Driver brake hose
GM Genuine Parts D1539JAmazonBrake Pedal Switch for Cruise Control
WAGNER OEX1194RockAutoRear Brake Pads
GM GENUINE 19420043RockAutoLower Intermediate Steering Shaft
The last thing I'm struggling with is my rack and pinion. I still get inconsistent return to center steering and after having replaced the entire front end and two alignments, I'm assuming that is the culprit. I've read mixed reviews on rebuilt units and was curious what everyone's current thoughts are on those. Happy to open another thread for that. It has been a great learning experience!
Here's a pic pre front suspension re-build, it sits much higher in the front now:
Welcome to the Forum from NH.
You've already done a lot of work in your truck, and it appears that you are keeping track of and documenting all of your changes. Another member here @swathdiver also keeps meticulous notes on all of the work that he does on his trucks, and he has an 09 Yukon.
C
claustralia
Welcome to the forum from Oregon.
That list looks like mine on my build thread for my Z71. I see the list. Tell me you saved all the paperwork?
It was a single owner before me which has every service record documented and I have continued. I have every link to every product and every invoice for whenever the inevitable warranty claim will come on one of the parts!
Helmetgurus
