Probably need new O2 sensors?
EddieC
I chased what was reported as O2 sensor issue and I finally found a break in one wire inside the insulation adjacent to the sensor.
It made for intermittent and odd error codes; too lean then too rich and so on.
I didn't find it before replacing the sensor and a number of other things; Just know it is possible.
dkad260
Use only GM OE sensors, even Denso branded sensors are calculated differently then the Denso sensors in the ACDelco wrapper. The tips are different too. It does make a difference if you are after maximum performance and efficiency.
Downstream sensors - 12609457 or 213-4229 (same item)
Upstream sensors - 12583804 or 213-3866 (same item)
I wanted to add to this. I just changed both my upstream sensors, I noticed the tips were different with the new Denso sensors. The sensors I removed only had a few holes near the tip, but the denso had numerous holes the full length of the tip.
How much different are these, if any...not sure of these are a suitable direct swap.
Mine are: Delphi ES20013 and have the 12583804 as an interchangeable item but that's not 100%.
I will say my driveability is much improved, still need to wait for a full block relearn to calculate MPG
Cool, keep us posted.
dkad260
Will do, I agree with you when dealing with electrical components to keep it OE. I couldn't find the OE on Rock Auto, so I will surely monitor economy and driveability, any hit on MPG they are coming out for sure.
First two drives have been very favorable though. I will start another thread as my brief history with the failing bank 1 sensor was different from past experiences.
dkad260
Check the wiring, then follow the troubleshooting guide. If the wires are good, it's either the sensor or ECM. Do the simple and less expensive checks first.
Your trouble codes are identifying the driver's side oxygen sensor after the catalyst as the culprit.
You asked me to keep us posted, and after my 1st long road trip with the Delphi upstream O2 sensors, I noticed about a 15% drop in MPG for the whole trip down. I could easily get 19.5-20 MPG on the DIC, real world about 19. This trip has been about 17 MPG.
The values (voltages) on the torque app seem good, but doesn't take much and I think I will swap them for OE sensors after this trip for confirmation.
Thank you for your update. Much appreciated.
j91z28d1
I have read that when o2 sensors foul they drift lean, so the engine adds more fuel. which happened much faster with the only 1 wire non heated ones.
the ecm then takes that added amount of fuel from the long term trims and adds it blindly to the PE mode fueling math. which is already overly rich from the factory.
same applys to most stuff today, but the sensors are much better and last forever and have more of them. back in the obd1 days you only had one and it died in 80k
dapdapdap
