How do you remove the rear audio control panel on an '02 Tahoe?
MadDogDelpho
Texcellent
Texas
I can't remember if it's in the top or the side, but there should be screws that hold the black plastic part with the actual cupholder to the door that swings up and encloses them. If you can get that off, then maybe you can access the other screws.
CMoney408
No problem! unfortunately I didn't download a picture of the diagram or I'd throw it on here.
You remember where you found that diagram? Just bought a 01 tahoe, passenger rear cuts in and out sometimes when I slam the door.
Driver rear doesn't work at all. I'm hoping bypassing the RAC fixes the issue. I just don't know which pins to jumper. Do you have photos of your jumper job?
I did install an aftermarket head unit and bypassed the factory amp.
I did have to keep/jumper 1 audio signal to the factory amp so the factory sub could still get an audio source.
Budzy24
