th3 shifty
Having this issue with the cam position sensor.
History of work done: I have changed the timing chain and made sure the dots lined up, I also changed the crank position sensor and O ring while I had the truck front end off. Last year I already converted to MPFI and changed the cap and rotor and it was running great.
I changed the timing gear as a “while you’re in there”.. since I was doing the gaskets for the timing cover, oil pan, and water pump. Never touched the timing or distributor.
Cut to yesterday I had previously started the truck many timing, it always idled at 800rpms and seemed to sound good. I would let it idle about 2-4min at time just to check for leaks and to cycle all the fluids during the resto. I start the truck.. starts just fine and idles well.. I get about 2 miles down the road and it starts to get rough.. and dies at a stop light after sitting there for 2more minutes. Pull code P0341 only. I bought a new sensor from Autozone, put it in today.. cleared the code, started up great, idled just fine.. let it idle for 10min… gave a few revs to 2500.. everything looked good.. go to back out, stumbles a bit.. then rough idle like before.. pull back in and shut it down. No code.. started again and it’s rough and set code p0341 again ..
Thoughts?
Thoughts?
