What engine does your 2000 Tahoe have?Hey do anyone knows about 2002 transmission on a GMC Yukon xl being able to fit inside 2000 Chevrolet Tahoe LS
maybe.. do a visual comparison, they made changes in 03 for sure so 00-02 should be good but there is a chance the transmission was different in 02, been a while since I looked into itHey do anyone knows about 2002 transmission on a GMC Yukon xl being able to fit inside 2000 Chevrolet Tahoe LS
The 2002 will retro-swap, if that is the case.5.3 v8
Use caution: 4L60Es with 298mm input shafts and corresponding stators designed to work with the 5.7/4.3 Gen 1 or Gen2 SBC / LT1/4 engine family are not at all interchangeable with Gen 3/4 small blocks and vise versa. The Gen 3 and 4 LS-based small blocks took a 300mm input shaft, 7-1/4 stator, TMBX/TLBX/TCBX converter (depending on engine displacement) and much deeper bell housing and will NOT retro to Gen1 SBC//BBC pattern engines as is.Should be fine. There were some different input shafts but I think they all switched to same shaft after like 1999 / 2000 (around time switching from 5.7 SBC to 5.3 SBC). I also presume both are a 4L60E.
Regarding the above, I agree with (some addl commentary where applicable):Some unsolicited tips: I'd do a few upgrades in the process though if you have it out... You can do these in the truck but they're a bit harder while laying on your back. Plus they're SUPER cheap to do.
- Sonnax plastic check balls (factory metal ones push through separator plate ultimately destroying clutch packs)
- Sonnax pin less accumulators (factory ones are plastic, they crack and leak)
- Corvette Servo (may already have it) - Holds band better so lasts longer.
- GET A NEW FLEX PLATE. I got the Summit racing SPI rated one. Cheap insurance as factory sometimes cracks.
- If high miles then also replace the electric solenoids, harness, diaphragm switch.
May also like to do... but can require some tuning.
- Boost valve
- OPTIONAL: Use Transgo's instructions to drill out separator plate when you have it out for check balls.
These are the weak points in the 4L60E IMO. I think factory started heat treating the sun shell and took care of issues internal to case around 2003??? Kind of hit or miss from what I'm told as they used up all the old non heat treated shells in builds. The planets, and shafts are awesome from factory and the clutches are good enough. The main failure is the metal check balls hammer through the separator plate after so many miles causing the clutches to not lock up.
