odd rear chevy lean on 2005 escalade esv awd
kemperboy01
Meridian MS
i have a 2005 cadillac escalade esv with a rough country 6 inch lift the lift has been on for about 2 years everything was perfect as far as measurements when i had it put on. recently i noticed it is 1 inch lower on the left rear vs right rear another thing i did notice is the front right was sagging so i had to turn the torsion adjustment bolt all the way to get the front even. i have taken measurements with full tank and almost slam empty. i have also replaced rear coil springs rear shocks rear control arms pan hard bar front shocks.also all sway bar links and bushings are good.yes i know some things do not have anything to do with it being off. some other things i tried is a spacer under rear left coil spring does not do much but lift the right side more i have also tried level torsion keys to see if it made any difference and it did not. i also have looked at all body mounts they all look decent i even replaced a few on the rear just to see. another thing i notice is when jacking up from the rear diff the rear left seems to take more time to get off the ground than the rear right i have 2 2010 tahoes the rear wheels lift at about the same time. all my tires are the exact same kind and pressure. i have been trying to figure this out for months maybe its just the "chevy lean"? and i have been going through it just replacing parts that look bad as well like torsion cross member mount bushings ball joints my question is can that front right torsion bar be so bad that its throwing the opposite rear side off?
Dremar79
