Transmission output shaft seal/bearing
diezelraccoon
Have a 2003 Chevy Tahoe LT 5.3 2 wheel drive. Having trouble finding the correct transmission output shaft seal/bearing. I’ve searched online but keep coming across ones that are different looking and want to be sure I get the correct one preferably OEM. If someone could point me in the right direction that would be great.
D
diezelraccoon
NickTransmissions
Sin City
The transmission bench
Refer to post #2 by @OR VietVet - he lays it all out for you. The first two links are for the OEM first design components while the third link is for the 2nd design which is sold at most places today.
D
diezelraccoon
The first two links are confusing because they are different. I need both of those for OEM? I’ve only seen videos of it being one part.
NickTransmissions
Sin City
Yes, they're different - you are looking to replace the extension housing's bushing and seal, correct?
If so, the first link is for purchasing a new OEM extension housing bushing. The 2nd link is for purchasing the OEM style shrouded extension housing seal. The third link contains a combo pack that comes with both the bushing and the seal.
Hope that clears up any confusion for you.
mingo8706
