2013 PPV side mirrors
SACK_U
My '13 PPV Tahoe has a smashed passenger mirror and will probably replace them as a pair.
they seem to be manual folding no heat with blinkers.
Can I upgrade to power folding with puddle lights?
Will the existing wiring support that? What switch will I need for this?
Hoeston
I had looked it up before and decided against it.
It is not plug and play to swap a different version, the connection is different to accommodate the additional wiring for upgrades
you need the mirrors, harness, door switches
once you have that it's easy to just plug-n-play
Shackman7878
San Bernardino
Your in luck I did all the research on that here:
Bradford333
