P0455 code troubleshooting
ReaperHWK
Have this code intermittently. It’s an EVAP large leak. I already:
1)replaced gas cap with OEM
2) checked fuel line between gas tank and filler.
I’ll still get the code to come on and clear itself. I also get the “tighten gas cap” message at time as well.
Anything else I should check that’s obvious before I start digging into this more?
FWIW my first guess would be an intermittent vent valve, or purge valve. Both relatively inexpensive and easy to change proactively, but also can be tested and diagnosed before throwing parts at it.
the sucky part is evap testing is difficult at best
it has to be done just right and when cold and if you mess up in the process, you have to wait and start all over again hours later after it has cooled back down
the vent valve is probably the easiest to test (the one on the engine) but it is also only $30 for a new oem one
the evap canister is $130
the vent solenoid is around $65
I usually just tell people to shotgun it (replace all ) and be done with it.
ReaperHWK
ReaperHWK
For those prices are I’ll just replace it. Is that the order I should replace?
No vent valve on the engine, it's a purge valve there. It sucks. With vacuum.
the one under the hood is pretty easy, the rest are up under the spare tire area by the gas tank
I would think the canister on a 2015 would still be fine, but no telling I replaced mine on my 2012 already
started getting the tighten gas cap crap and knew then it was time to do it.
it takes time for it set as well when you replace something and clear the code it normally takes about 3 days to see if the code stays away or not.
if you make it past 3 days and no code the chances are good you nipped it.
I would highly recommend oem parts in any case, the aftermarket ones tend to fail in no time at all
The procedure for testing is not that difficult with a decent bidirectional scanner. Even an inexpensive scanner can show the fuel tank pressure, which is a major part of the test data. A purge and seal test can show a lot, if you want to do actual diagnostics. If that's not right for your situation, do the parts and pray.
You're correct about the onboard emissions system test being finicky about the testing conditions.
Near the end of this video Eric O shows the purge and seal test, and how to understand the fuel tank pressure and vacuum decay.
MORE: Mike at Wells does a great job of explaining and testing:
ReaperHWK
ReaperHWK
I did notice my scanner has the EVAP test. I tried to run it but the coolant was too hot it said. Seems like a ton of conditions needed to do it. Maybe I’ll look into it more.
But my car is 9 yrs old maybe it’s better just to replace this crap?
KELLION
