Digital Climate Control Issue
bubbz22
Hello all. There are plenty of threads on this forum about HVAC issues, but I didn't really see any like what I have going on. I have a 2004 Yukon. It has the digital dual climate control. I noticed some weird issues today.
To start with, is the O button on the far left supposed to be power to turn it on and off? Mine only turns the unit off, and sometimes takes a couple of presses. I have to turn it on by hitting the auto button.
Next, I had it on this morning, set to 72 and it was set at face(ac off). After a while, I noticed there didn't seem to be air blowing towards me. Put my hand to the vent and verified no air. I pushed the button that changes mode and it showed just feet. I know I didn't change it. Should it change itself?
And the last issue. This afternoon I was driving home. Again, I had it set blowing to face and after awhile I felt no air again. This time I looked down and it was off.
Do these issues sound like the climate control module is bad or going bad? Or are they things that should happen? Or possibly something worse?
This is the unit, button circled from first question/issue. Also, the second, fourth and fifth buttons on the bottom don't light up at night. They should, correct?
Thanks!
SilverSport
that "O" button only turns the HVAC OFF...not ON...do you have a copy of your Owners Manual?...if not you can find one online so that you can download (or at least view) it to have it for access...
the MODE button is the one you use to change where you want air to blow...don't use the AUTO setting as that lets the Yukon to decide where to put the air...
if you are having other issues with where the air flows, it could be a blend door issue or some other issue
Good luck with your Yukon,
Bill
B
bubbz22
Thank you Bill. I didn't even think to read the manual, I just assumed something was wrong. All seems to be operating as it should, other than the worn off parts and lights that don't work.
Aquamania001
I have that unit in my Tahoe and the temperature dials that select the temperature are not working 100%. They don't select the correct temps and you really have to work with it to get it to work at the right temp. Where can I buy another unit to replace this one?
You can clean the pots with electronic cleaner. I did mine while I had it apart to replace the backlights, but it can be done without removing the head unit.
Pic here of what the circuit board looks like underneath all the prettiness.
Meg_az19
