Dual exit pipes question
rick1024
Fort Worth Texas
does anyone here have an exhaust that has split exiting pipes going out the rear of the vehicle instead of the side?
like a dual exhaust? can you post pics, especially if it was a custom job?
thanks in advance
Trey Hardy
Eastern North Carolina
thanks in advance
Mine are coming out the rear by the Reese hitch but their axle dumped 7x18” tips
I wanted most of the tips to be hidden that’s why I axle dumped them vs the typical Texas style
no pics but in the past i have had dual tips on both the 800's & 900's the k2's are not inherently different a good muffler shop can do it, they just have to keep in mind it is a floating rear axle so the pipe has to go high over the axle or it will/can bottom out
tooleyondeck
Northwest FL
While it's not the same generation as your K2X, it's the same concept. I like the straight-back orientation over the 45 degree angle I see a lot, but that's just preference, it doesn't change the sound. I have x2 Jones Performance Flowpacks (true duel, no Y pipe) and 4.5" tips, cold start video included.
az5950
My Setup, custom from 3rd cat back with Flowmaster Super 10
CharlieD139
