99 Tahoe 5.7 vortex P0300 code HELP
M
Mackb23
So, a quick update, replaced the pcv valve along with the hose connections, and it’s not bogging down when I take it out of park, still throwing the code and running a little rough, gonna dig some more into it this weekend, would any one suggest getting new grommets for the intake?
east302
Mississippi
They can seep oil over time, wouldn’t hurt to swap them if they’re original. They’re the same part for both valve covers.
As others mentioned, aftermarket distributor caps are a weak point.
Follow the hard vacuum line from the PCV fitting over to the solenoid on the passenger firewall. Make sure it isn’t broken somewhere. From the solenoid is another vacuum line to the heater valve.
M
Mackb23
Okay yeah they’re original. Came with the new motor, I’ll get some, I also just changed the MAP sensor, what’s the best way to check the hose from the solenoid to the heater core ?
east302
Mississippi
It’s just a rubber hose from the solenoid to the valve (#14 in diagram) so it can crack over time. The only way it could cause a vacuum leak is if the solenoid is energized - when the a/c temp dial is in the Max detent.
#20 is the hard line to the PCV fitting.
Primetimetoons2
