99 yukon 4wd service light code c0310 help
JEFF LIL
JEFF LIL
And one more thing I noticed when I turn the key on the lights turn on and go of within seconds don't know if that makes a difference
Sent from my XT1080 using Tapatalk
SunlitComet
OBS Jedi-Do Good
unknown at this time.
then the switch is getting power as it should then. You have access to the scanner that will let you command functions of the t-case for testing purposes in addition to just puling codes? I have some diagnostic pages I would like to email you and one of then requires it.
JEFF LIL
JEFF LIL
SunlitComet
OBS Jedi-Do Good
got the address, several documents on the way shortly. Edit your last message and wipe out the email. In the future t avoid spam-bots you can just private message users here by clicking on the picture and choosing contact info.
Justin Kase
So I have a 99 Yukon as well. What ended up being the problem and the solution of you have one?
CaliCrusin
