NYBRD
Woops, my video didn't upload anyone know of an easy way to attach a video ?
K2 Kaiju
The Depths
I got my Hellwig sway bar in a couple of days ago and I am pretty shocked at how improved the ride and handling is. I can't really say for sure that I ever got a fair shake with the Hotchkis but it WAS a positive improvement over my 10 year old stock bar and bushings at first at least. The hellwig in the front so far seems like a much stiffer bar (based on how heavy it is) if I had to guess and it really corners noticeably better now and just overall feels good.
I will freely admit that the Hotchkis bar is noticeably nicer for fit and finish. There was even a spot in the steel and powdercoat both right where the bushing would sit that was sharp and I sanded it smooth with a flap disc BUT Hellwig managed to pack the right brackets, bushings and hardware with my sway bar so that's a clear win for them over Hotchkis just for that. So far I've driven it pretty hard including a lot of harsher-than-necessary cornering both up and down grades and the bushings are still in place and the Yukon feels better than it ever has!
After having both, I agree the Hellwig is better.
Walkerfever
Missouri
How much did you save DIY?
Hard to say, I have no idea what this would cost to be professionally done. I paid $35 for the media blaster, $28 for the Walnut shells, and $7 for a bunch of rags at Harbor Freight. The vacuum adapter I put together and 3D printed made the job a LOT less messy and easier. Without it, I'd be picking shells out of....everything. If anyone has a 3D printer and wants the STL file for the adapter, just let me know!
I'm still hunting for a spacer for behind the GMC emblem on the Denali grills so that I can 3D scan it and have an STL for that, too. Seems like that spacer is like unicorn teeth with these Yukons.
hellercole
