Useless Information
It's been an eventful time since my last on here. Plagued with physical problems and 2 pregnant dogs and all kinds of stuff going on.
At one point we had 21 dogs in the house! First dog had a litter of 11 of which 9 survived and all were adopted out. Second dog had 9 and all survived delivery and are about 2-3 weeks old right now, eyes still closed. Needless to say we've run out of candles and air filters! LOL
The 14-Bolt, 9.5" Axle project is nearly complete. We are into the break-in period now.
I purchased a used complete IFS with 3.73 gears and my helper installed it with new mounts and GM CV Axles of the latest design intended to keep more dust out of the rear of the knuckle/hub. He also replaced proactively the other Timken hub with a GM OE unit and new bolts. In the interest of time and because none of them were bad, we kept the universal joints. So far it's working flawlessly even in 4LO and even the original actuator it came with.
We put new parking brake shoes and axle shafts onto and into the 14-bolt rear axle and new anchor blocks for the parking brake cables and new rear brakes. Speaking of which they lasted 84.899 miles with about an 1/8 inch of material left. I could have left the rotors but changed them for new. The axle has run flawlessly with no noise so far.
Sometime after the next refueling we'll pull the cover and inspect the inside and refill it with fresh fluid and drain and fill the front and inspect the magnet.
I'm delighted beyond words that this long project is over. Now I can get the garage cleaned up and better organized and get to the long list of wood-working projects that have been put on hold for years because of these axles and parts taking up my work space. Thank you to my helper and most of all to the Lord!
I had wanted to document this with photos but could never remember to, sorry fellas. This is all I have:
Back in August I wrote on another thread that the battery died and how the RR Wheel Speed Sensor and RR TPMS sensors both died seemingly as a result of trying to jumpstart the truck.
My daughter and I replaced the sensor but we could not get it connected. My helper came over and connected it but the code was still there. A visual inspection of the wiring and connector at the ABS Module were done and all seemed well. I bought a new ABS Module, installed it and successfully programmed it with my MDI and laptop. It still threw a code on a test drive! Right before we removed the old axle, we hooked up a new ABS Wheel Speed Sensor and voila!, no more code.
So remember folks, even new parts can be bad, or get broken by folks with two thumbs!
The TPM system is throwing codes for the front sensors but not the RR. The RR shows up as dashes in the DIC but stays at 27 psi in the Tech-2 while you can see the other three tires heat up and cool down on a drive. The Tech-2 says the other three sensors are reading low while the RR sensor is reading normal. Crazy stuff going on in there. Before replacing the RCDLR, I'm going to replace at least one and maybe all of the TPM sensors as they are now about 9 years old and have been on the car for around 7 years. The previous sensors never made it to seven years. Almost but not. Thinking of what the most economical way of doing that will be, that and the least aggravation and physical pain! Tires are three years old and at half life tread wise, about a year left to them dry rot wise in this Florida sun.
89Suburban
Bull in the china shop
SE PA
Good to hear from you
View attachment 443319View attachment 443320View attachment 443321View attachment 443322
Love the prototypical "pumpkin!"
The long term projects are the ones that are the most satisfying when finally completed.
What kind of puppies are they? Pics or they were never there lol.
These two are sisters and the two mommies. The one on the left (Rusty) has had her litter adopted out and the one on the right (Rosie) just has hers about 10 days ago, I lost count. Dad is a full breed English Lab with papers. I'll have to get a photo of him and the pups from the girls. They don't send me photos anymore, just upload them to social media for everyone else to see! LOL
All of the pups from both litters are either brown or black.
Well, my daughter is trying to email me pictures from her phone, these are the only 3 to come in so far:
So we have Levi (Dad) with Moose, then the fella in red is Rooster and in blue is Buck. Rooster stole my heart and if we didn't already have 5 dogs I would have kept him. Buck and Moose were more playful but good boys too. I never wanted to do this because I want to keep them all! We didn't want to have the girls fixed until they were mature, after their 1st or second periods. Well, Levi got to them when we weren't looking!
We don't keep girl dogs anymore because of their general temperament compared with the boys, suits us better. However, Rusty and Rosie and their whole litter of 7 was abandoned out in the woods and my girls took them all in at 2 weeks old. About a year before that, they found an abandoned litter in a box at Plant Bamboo and raised those pups, keeping one and adopting all the others out.
yukonxlwestcheste
