homesick
- Joined
- Sep 19, 2018
- Posts
- 1,474
- Reaction score
- 3,859
I thought there was washer fluid of/with alcohol, to prevent freezing. No?
joe
joe
I did with a similar unit. There is a Hyundai/KIA unit on ebay. It was cheaper awhile back..gm attempted to make heated washer fluid but it didn't go so well..... you can still retro fit maybe
Not sure what's in the winter blend, but it's not available in california apparently.. I'm going to have to order some from ebay..I thought there was washer fluid of/with alcohol, to prevent freezing. No?
joe
... I mean, it's called a Tahoe.. I'd like to be able to drive in Tahoe...
They had a tendency to have a thermal runaway when the 60 amp heater would overheat and start on fire.
Something like this works great if you can actually find the correct size. Put it on when you park it, pull it off and the windshield is completely clean.
Golf clap for this comment. If every OEM added every nuanced feature for this "$XXXk" suv then we'd have $200k+ SUVs that nobody can afford.What else do you want, and how much more do you want to pay for these trucks?!
The defrost works fine with remote start. Check your settings.
