7 pin connector trailer plug
I can't tell what you're doing since I didn't understand your response. If you're bypassing the harness connector I posted and wiring directly to the 7-blade connector, it's something I wouldn't do. I also don't know what 7-blade connector you have, so if it's aftermarket with screw terminals for the wires, I guess that would be easy enough to do it directly. But if the new 7-blade connects like OE, then I'd think it easier to use the harness connector.
flipharvey187
