Remote Start Troubleshooting - SOLVED
DaveO9
DaveO9
Vancouver, WA
Found a company that does TCCM programming...
Thanks, I will contact them to see if they can help.
One thing I was thinking about, regarding the fact that RA does not list a TCCM for single speed t-case: I wonder if the 2-speed one covers both single and 2-speed? I noticed that my original TCCM P/N is listed in the long list of OEM TCCMs it replaces.
Thanks for posting these screen shots. I went through every parameter and compared with mine. The only one that was significantly different was "Range Actuator Command" - yours is 0%, mine is 49%. Not sure if that means anything. I was doing the diagnostic key-on, engine-off, in 2-high. Looks like you were in 2-high as well.
I re-ran the ATC learn procedure with the Tech 2, just for grins. No change to remote start status.
mikez71
Interesting, I was also key-on, engine-off, 2-hi.
And your theory makes sense why we only see one TCCM module forsale.
Might check what the Tech2 shows with your old TCCM regarding "range actuator command"
ACDelco lists 24261367 covering the NP0, NQF and NQH transfer cases.
DaveO9
DaveO9
Vancouver, WA
Looking at the cardone brand on rockauto, it says "vehicle specific programming required ON the vehicle."
While not cheap, a new Dorman module looks to be $120 after you return core..
I'm thinking not a whole lot more than having a dealer reprogram.
(I'd pay that to avoid going to the dealer!)
Return it if it doesn't work. Send the core in if it does work.
(unless the Dorman requires programming too, hopefully they bypassed the VIN programming..)
I finally ordered the Dorman unit today from RA. We will see in a few days if it works!
Hmmm, interesting. Since they all use the same module now, it would seem as if I should be able to find someone that could reprogram my original 24261367 to work with the 2-speed. I will look into that further if the Dorman unit I just bought doesn't solve my issue.
Just logged into ACDelco TDS and got big messages about using counterfeit clones (J2534) and a warning that doing so would get one locked out.
Anyhow, I plugged in my '13s VIN and saw a menu description for programming all three transfer cases and then part numbers for what I believe were the two 2-speed variants.
mikez71
Awesome! But since they show part numbers for the 2 speed xfer module, possible original 1 speed modules can't be reprogrammed to 2?
But angry because they gotta screw with us little guys trying to program our own modules they made this stupid way..
there must be some ***** ones out there my clone mdi updated with the bosch software multiple times and never have had a issue
this is there warning message on the website
Access Unauthorized with Destination System Error
ONLY if you get an Access Unauthorized with Destination System error - This is more than likely caused by the use of a counterfeit MDI or MDI 2. Aftermarket J2534 devices are not impacted. Please use the contact us form https://www.acdelcotds.com/contactus instead of calling in for support.
WARNING- USE OF COUNTERFEIT "CLONE" GM MDI DEVICES
will result in your account being locked. Aftermarket J2534 devices are not impacted
z33garage
