newbie question
jrib
Hello everybody. I just purchased a 2021 Yukon Denali. I would like suggestions on some all terrain tires to put on it that are not too aggressive looking and can maintain a decently smooth ride. I love the open country MT but I find that they ride a bit too rough after about half the tread is gone. I plan to use the stock 22" wheels. I will probably stick with th same tire size so that It doesn't effect the speedometer. I do have the air lift suspension. Can I adjust the front only just to get to level or do I need to install a leveling kit?
B-train
I would go with the Falken Wild Peak tires. They seem to have a good tread, nice look, and from what I've read are pretty decent overall. I'm also a fan of Bridgestone Dueler AT tires as I've run many sets of them over the years. I currently run Nitto Terra Grappler G2 tires. They have great traction and look good but, they do ride a bit rougher than past tires I've run. These are also on 18 inch wheels as I've ditched the 22 inch ones in favor of a better ride and hopefully lo get life on front struts.
Consider running a P-Metric or Load Range C tire instead of a Load Range E tire.
What kind of terrain do you want to traverse that needs an AT tire? I've gone just about everywhere with my Michelin Defenders that we went with our KO2s off road without issue. Michelin makes a good AT tire too.
CCPLuvr
I just put Wildpeak AT4W, 35x11.5 on my AT4. I've found them to have a noticeable hum and can feel that they are stiffer than the OEM tires. Not sure the wife is in love with these yet as am considering taking them back for Nitto Terra Grappler G3s.
Bigburb3500
I run the new BFG KO3s and really like them. Have had KO2s on my Toyota for yrs (multiple sets) and they are great too, the KO3s are even better. Quiet and lots of grip as I have had the KO3s on the beach multiple times and offroaded the KO2s plenty of times.
Carseller235
