Yukon rear storage options
martone
I recently purchased a 2024 Yukon SLT and looking to find existing rear storage options. I've used the jack compartment and shallow storage inside the lift gate but need space for a small air compressor. Any thoughts?
motorswin
Can you mount one under the car like the on board systems guy run for air horns or filling up tires?
TrueAt1stLight
Minneapolis
I have a high volume compressor (I don’t recall the name but can look tomorrow) that sits under the rear cargo area.
oldtimer
Santa Clara County, CA
Is your compressor smaller than a battery?
There is a space behind the driver side panel in the cargo area that holds the second battery in the PPV.
KMeloney
Is that where the sub is on non-PPVs though?
Outahere
I have a 2016 Yukon and there is room under the hood opposite side of the battery if the compressor isn't too big.
M
martone
Thank you all for your responses. I guess aftermarket is the solution for me.
Vladimir2306
To store a towbar, compressor, and other things, I bought an expedition box; it fits clearly across the entire width of the trunk, and has a depth of 30 cm, without sticking out much beyond the backs of the third row seats. It fits a huge amount of things.
tdeaton3
