Hi all fixing up my 2003 tahoe - Window switch issue
Wilk 2003 tahoe
I just replaced my left rear window regulator and new switch for rear door, I have full control from the driver master panel up/down but from the new switch in rear door only goes down ? Bad new switch? What else should I look for?
Test the new switch with an Ohm meter, to be sure that it is not the cause of your issue.
Welcome to the forum!
Moved you here from the patiently-awaiting-for-the-EVs section.
PartsTester3000
