tom3
- Joined
- Jul 15, 2019
- Posts
- 1,132
- Reaction score
- 1,804
Sure appreciate it if someone would give me a measurement from the bottom of the stick to the fluid line on your 6L80 trans. dipstick when sitting level, cold, and engine off. I know this is not how it's supposed to be checked but:
Did a filter and fluid change on the 6l80 (2019) transmission. Pulled and drained 5 quarts of ATF, put in 5 to start. Got it hot and idling and started checking it. That D6 fluid is so thin and clear when hot and that long stick gets coated going back in seems like. I cannot get a good reading on it. Stick is wet, just can't see a line, front or back of stick. Did add another half quart to allow for drips and filter but really need a check to sleep better. Cold check is better than nothing? Sure never ran into this before.
