2009 Tahoe PPV-no turn signal chime and radio dead
vetterss
Double Oak, TX.
All of a sudden today the turn signal chime and radio went dead. Have not had time to check fuse yet but was wondering what other options I can check later on today?? Does anyone know where that particular fuse is?
PPV12HOE
NC
I can tell you all the chimes run through the radio... so if the radio is inoperative none of the chimes will sound... most aftermarket radios have to be hooked up with an aftermarket data link and an e terminal speaker to get the chimes to sound...
Tigersfan21
Have you had any luck finding the problem? I have the same issue!!
QUYHMK
