Technically, the GMT900 HDs were made in 2014 as well. But I know what you mean. Just happy to have finally confirmed that the trusty old Tech-2 will work on a 2014 GMT900. I'm trying to talk my wife into one instead of a much newer and more expensive 2025. I want land and a shop, not another car payment!
that's been confirmed a long time ago. I helped out guy that is probably no longer on here but lived close by and did a nav radio upgrade on his 2014 2500, we connected to sps and did the unlock and then all he needed to add was a gps antenna and it worked like a charm.
when you are using the tech2 it doesn't "really" go by year, it mostly goes by the vin letters.
it does ask for the year but (I THINK) that's only because some features were added or removed over time.
I can go tell it mine is a different year and most of the functions will still work fine
When it is/was used for programming via the pc all you do is connect it and turn it on, the computer does the rest via the vin number that it reads from the vehicle
Thumper68
Changed the front,rear differential fluid. Did the transfer case as well. 216K on the clock. Rear differential oil looked new, found 2 small metal shavings on the plug. Front differential oil was slightly milky. Small shavings porcupine on the plug. Transfer case fluid was dark and dungy. Medium sized porcupine of shavings on the p,ug.
Charlie207
LFOD, New Hampshire
Replaced both lower ball joints, to comply with the failed safety inspection. Now I just have to wait for the EVAP system and O2 Sensor heater readiness tests to complete. I recently changed the rear O2 sensors, and I guess it's been too cold for the emissions system to run all they way through its tests.
Grady_Wilson
Wyoming
ordered a new sunroof switch, mine works but the lights are burnt out which is not a big deal but I have poor soldering skills and all the other lights work so...... why not
and stupid passenger side mirror I replaced last year after hitting another mirror on a big ass truck parked halfway in the road, the power fold motor took a dump so I will throw my old motor on it that still works fine
That is good price.
One of the switches on mine has an intermittent light, if I notice it is not lit, I can tap it and it comes back on.
For that price I will order one and just replace it.
89Suburban
Bull in the china shop
SE PA
It’s my understanding you have to drive about 50 miles to get the monitors to reset.
Grady_Wilson
Wyoming
I wonder if this tactic might work to allow me to finally recalibrate the steering angle sensor on my '07. I installed a new one a few years ago but messed it up when the wheel moved ever so slightly before turning the key on, and now as soon as I turn the wheel the first time after starting, I get the Stabilitrak/TC off warning. I don't even notice it any more, but I would like to fix it without replacing the thing, but it's not an option on the GMT900 menus. Going to play around a bit and see.
Most better scan tools can reset the steering angle sensor.
Mine has a SAS reset function.
That is good price.
rockauto has it for $27 but then they hit you for shipping & tax, I use my business account on amazon and it's $36.xx so free ship and no tax
rockauto will do no tax on a resale but I haven't ever submitted mine to them
let it sit overnight and then take it for a 55mph cruise about 20 minutes down the highway and back and if possible take a side road without hitting the brakes and let it slow down on it's own to almost a complete stop, then let it sit and idle 5-10 minutes a couples times, repeat for a couple days and it should set
That is good price.
Huh, discovered there are 2 different versions luckily the buttons can be swapped otherwise won't fit the panel because of the gap in the middle. Was just messing around in the junkyard and got this one for free, they gave it to me, lights work I can return the one I ordered 1000006152.jpg
On second thought I'll probably just put the new one in when it comes, this one lights up but not much, but there are 2 styles for future reference, the one with close buttons came out of a 2008 with the rear folding seat buttons that they deleted
Scrivers
