Lowered 04 Denali
Goliath23
Goliath23
What type of drop parts did you use?
Front
Spindles, torsion keys?
Springs w or wo shock extenders
Front i went drop spindles so less stress on the bushings and suspension and rear has lowering springs with all the relocation brackets and adjustable pan hard bar.
ivin74
05 NBS Nali
Htown, Texas
Since you used the spindles on the from any good aftermarket shock will work. The suspension geometry did not change. For the rear, if you add the shock extenders you can use any aftermarket shock aswell.
89Suburban
Bull in the china shop
SE PA
Pay attention to the extended length measurement of the new shock. At full droop you want to keep your springs still snug in their perches. On my 07 I think I went with a 19” with the 2” drop brackets with my 5” springs and it was perfect.
Allthingschevy12
