- Joined
- Aug 2, 2018
- Posts
- 7,799
- Reaction score
- 10,758
You are only 5 psi below the 'normal' 20 psi at hot idle. As suggested above, a used oil analysis would be a great place to start, in order to further investigate your current situation. Also as mentioned above, checking out the contents of your used oil filters for any additional metal pieces is also a good idea.
I just installed new lifters, new cam, and a new oil pump as part of my motor upgrade project, and I have 20 psi at hot idle, and by 1500 rpms, it is at 40 psi or higher.
As @petethepug mentioned, the L92 motor is a rare prized racing motor, due to its non-AFM construction, and you can demand a good price for it, if you end up doing a motor swap.
