0 reading temperature gauge STILL after new thermostat and ECT
Tilly2025
2018 Yukon Denali had CEL and temp gauge read 0. Replaced the ECT and thermostat today, no change.
It’s been like this for a week. There iwas one day when it worked again before the new parts.
Bonus issues—getting a rumble strip feeling when accelerating around 1200 rpm. Have an appointment scheduled. Torque converter?
L8T BURB
Kentucky
You've got a stored code for "coolant temp below threshold". This code is what causes the temp gauge to drop to 0 and the other fail safe modes to activate. You will need to get that code cleared before things will work. If you don't have a pocket scanner or similar to clear the code yourself, I believe you can disconnect the battery for 30 minutes or so and it may clear it.
Bagherra
Va Beach, VA
Same issue here, just replaced the ECT sensor 2 days ago and temp dropped to 0.
Thought i cleared the code but i guess i didnt.
L8T BURB
Kentucky
If your temp dropped to 0, the root cause is a faulty thermostat. If you haven't replaced the thermostat yet, clearing the stored code will only temporarily work. The lasting fix is replacing the thermostat and then clearing the stored codes.
Bagherra
Va Beach, VA
When replacing the ECT or thermostat, and there is a loss of some coolant..is there a way to make sure there are no air pockets after everything is replaced?
TahoeInterceptor
