Starting and staying running issues!!
stormtrooper777
stormtrooper777
Tell us what you're working on -- year, make, model, and engine. Then start with some basic tests, like fuel pressure, spark, etc.
2007 tahoe lt 5.3. Like i stated in my original post ive gone through all steps and replaced most sensors. Have fuel pressure, spark and air just won't stay running
stormtrooper777
stormtrooper777
Need more specifics on what you did. Were you looking to delete the AFM/DOD.... Or are you only replacing the AFM lifters?
Note.... It's not usually the AFM lifters that fail, it's usually the solenoids that control them. As much as I cringe at the thought of attempting to maintain the AFM system, to do it correctly you should replace the VLOM after removing it.
Reading whatever trouble codes exist is where to start.
I am not looking to delete afm. I just wanted to replace lifters so I didn't have to down the road. I've owned 8 tahoes and suburban with ls 5.3 and never have ran into this ever.
j91z28d1
I'm so confused by this thread. can you get a video of this happening?
and did you put new afm lifters in, or non afm lifters? if afm, where did they come from. I've seen so many posts of guys having to go back in a 2nd time because they used Amazon or ebay afm lifters and it wouldn't run right. oem or millings only.
video would help, but if you're saying after it starts, revs up and dies, the starter can't spin the engine over anymore. unless you have a bad connection to the starter, that sounds like it's running so rich it's flooding, stalling out and dying. then it's hydro locked with so much fuel the starter can't spin the engine over? I didn't even know this was possible lol.
after it dies pull the plugs and look for raw fuel. byond that you're going to need a decent scanner and know what you're looking for. I don't know what basic tests are you're doing over and over or what sensors you've replaced(there's a lot of them) but they don't seem to be giving any info that you can share with us?
wjburken
Eastern Iowa
The list of parts is listed.
Sorry, I was asking about what all was changed when you swapped the lifters, not what has been swapped out after you had the starting issues.
VLOM gaskets?
Intake manifold gasket?
Lifter trays?
I’m am assuming you have checked all your coil and injector harness connections.
I feel your pain. A number of years ago I replaced all the lifters and the cam shaft in our 2007 due to a locked up roller on a lifter. When I got it back together, it wouldn’t even turn over. It turned out to be my starter that decided to lock itself up while sitting waiting for me to get the motor back together.
stormtrooper777
stormtrooper777
You won the correct answer today. And a huge learning experience for me. I will never trust Amazon with engine parts again.
Pulled the head and put the old lifters in and what do you know it worked!
Thanks everyone for the help and advice
j91z28d1
I'd love to see if you see any difference in the injectors over the stock ones.
clublub69
