Can't Remove Hitch Pin, Not Rusty
My Brothers Taho
I towed a (5 x 8-ish) single axle trailer 5 miles loaded with a Case 222 lawn tractor. It appears that the hitch flexed, and the formed end of the pin rotated down into the slot for the safety chains.
Is this a "normal" thing? Is the hitch that flexible?
I should be able to get it out by removing a little material from the end of the leg but do I have to?
Grady_Wilson
Wyoming
From the looks of the first picture, the pin was much smaller than the hitch pin hole.
It allowed it to move up and down, along with allowing the hitch to move inside the receiver.
This caused the pin to move upwards during the movement of towing and get inside the safety chain loop.
I would see if you can lift the hitch bar enough to move that pin up to rotate it out of the loop.
Or, you could just cut the pin and source the proper sized pin for the receiver.
PPV_2018
Senior Member
U.S.A.
Putting some weight on it / jiggling it plus a BFH tap from the left side couldn’t break it loose?
Push down on the ball to lever the pin up into the high point of the hole, then turn the pin with something persuasive. Maybe hook up a heavy trailer to apply the weight to the ball.
89Suburban
Bull in the china shop
SE PA
Are you sure the tow chain/hook didn't get too tight in a turn and bend the pin? Cut it off with a dremel or sawzall or something.
Maybe use a floor or bottle jack with a piece of metal stock to push/pop it up out of the hole somehow.
Geotrash
Dave
Richmond, VA
See? This is my kind of ingenuity right here. Whenever I encounter something like this hitch pin, my mind immediately goes to the biggest, strongest tools I have to get shit going the right way again.
If you can't fix it, force it. If it breaks, it needed replacing anyway.
homesick
I don't think I'd reuse that pin, regardless of everything else.
joe
mecanico448
