2008 Tahoe Wipers Not Working
eb5665
I have a 2008 Tahoe that the wipers are not working. We have power and ground to the plug that plugs into the motor, the fuse has power to it as well. We have tried a new motor and bench tested the old motor and it moves when given power and ground. We have also tried a new switch as well.
When you test that power at the connector try using an auto light bulb (as a test light) that has about the same amperage draw as the motor. Loading it with a bulb may show that circuit can handle the current, or not.
CG11
