89Suburban
Bull in the china shop
SE PA
Plus I wanna make sure all the bugs are worked like like the one I am dealing with now. I was wondering maybe if there is an injector that got something stuck in it from the R&R process.
Wise choice. How many miles on your trans?
No clue other than I know it's been rebuilt once. So 360K / 2 = 181K to keep it simple.
When I went to lunch today it was worst cold start yet, cranking 1rst time no fire. Crank 2 very long gave it some pedal fired up a few seconds afterwards big cloud of black smoke. Cleared right up and ran fine.
Shit's fkn with my OCD. Going to double check some simple things like the PCV hose air box to the right side VC. Too cold to fk around with it right now. It is starting to irk me I don't want to be gas washing the oil off the cylinders on cold starts with a new motor. Puzzling no codes or engine light.
Look at fuel trims. Could be something as simple as the purge valve on the engine staying open when it shouldn't, letting fuel vapors into the intake (flood condition). Otherwise maybe sticky injector.
Next time it cranks but doesn't start, floor the accelerator and use clear flood mode, see if it starts then.
89Suburban
SE PA
I have no scanner to read those.
I remember the shop that put the motor in telling me a hose on the purge valve broke during R&R and had to be replaced. Maybe some debris got in there? I will look at it over the weekend. Make sure everything is connected properly and such.
I will try that clear mode next time. Thanks big F / Sammy.
TVan
