Oil pressure sensor HELP!!!! - SOLVED
Spencer4991
Does this look to have a filter in it??? I have fished a hook in but can’t seem to grab anything and the new filter(not putting it in) doesn’t fit all the way down…. 2010 Chevy suburban
j91z28d1
were you able to get one out? I can't tell in that pic at all
I can't tell if there's a screen in there or not. Some people take a long deck screw or the like and stick it down there, turn it clockwise by hand and pull them out. YMMV
S
Spencer4991
I wasn’t able to get anything out….ill try a deck screw tomorrow, I’m dropping the pan anyways to change out the pick up tube gasket. I’m trying to cross everything off before replacing the pump.
Looks like a larger screw might work better. 5/16" lag maybe...
Welcome to the Forum from NH.
Pics of the truck, please.
Not all of these motors had filter screens. @Doubeleive may be able to clarify which ones did not have a filter screen.
rdezs
I'm thinking that most likely looks like one. Should lift right out with like an o-ring pick tool
Smityinms
