On a 2019 GMC Yukon xl denali 6.2 10 speed Transmission - Does it sound correct that GM recommends a Drain and Fill and not a "Flush"?
Wilmington, NC
On a 2019 GMC Yukon xl denali 6.2 10 speed Transmission - Does it sound correct that GM recommends a Drain and Fill and not a "Flush"? Does the Crossmember have to be take out? Really? Tks
Big Mama
Virginia
here’s a thread.
Marky Dissod
If the 10L80 is suffering no drivability symptoms, then a drain & refill is reasonable.
I'm sure someone knows how to push more ATF out so that more fresh ATF can be put back in vs a simple pan drop.
(How many miles? The more miles, the more badly you want a flush.)
tom3
Doing my 6L trans. every 30k miles or so and I do drop the pan, new filter and 5+ quarts of fluid. I want to see what's in the bottom of the pan and clean the magnet.
Ta6112
