‘97 Yukon work horse
exp500
NorthernYukon97- The best way to eliminate the EVO system is to replace Steering pressure hose. Use a 96 hose. Disconnect wires from EVO valve at P.S pump, unscrew EVO, Reconnect wires and tyrap securely out of the way.(leaving valve connected fools computer. no codes) Install 96 Hose. I like to re-shim pump for better feel too(see other steering posts).
EVO increases flow at low speeds when working properly, just a solenoid valve. So when it does it at the wrong time its dangerous/ why there is a bypass kit. Should have been a recall. (96 hose $30, Kit $60 and one more fitting to leak.
NorthernYukon97
NorthernYukon97
Thank you exp500, appreciate it. I’ll look into that. It’ll be my next project in this truck.
Cheers,
exp500
NorthernYukon- I forgot to mention the flow control valve in back of pump. A hex headed fitting that the pressure hose screws into. Almost any metric saginaw will work, need a throat dia of about .110-.140 . Hydroboost about .160-.200. I usually replace the pump too with a 96 that has it installed already.There is a spool,spring and ball behind, so careful when removing EVO also.
89Suburban
Bull in the china shop
SE PA
NorthernYukon97
NorthernYukon97
Hi guys, decided to get the Yukon ready for another winter. I picked up that bypass kit, haven’t installed it yet. And looked at the rear defroster. Cleaned up the contacts, and found one plunger stuck. Before I bought another one, figured I would see if I could fix it. It’s is serviceable at the end of the day. Disassembled it, cleaned everything up, cleaned all the contacts, and res installed it. We’ve had a couple frosts now, next frost we get I’ll give it a try and see if it works now. A few pics.
I’ll report back either way if it worked or not..
:cheers:
NorthernYukon97
NorthernYukon97
Why was this thread moved to pictures????
I don’t even know how to find the pictures forum??
raceguy13
