01 Mirror Glass Replacement
StewTCB
Oly
I have an 2001 Tahoe LT. Need a driver side mirror replacement glass. Power/Heat/Autodimming. I can only find heated mirror replacements. Any ideas? Thanks.
jomulk56
Resident Lurker
IN
Do you need just the glass or the whole connecting unit? The glass has a plastic piece that connects it to the mirror housing. If that's not there you'll need a whole new mirror.
02 Burb
California
When someone smashed my drivers side mirror, They paid for a new mirror insert that was Power/Heat/Autodimming for 400 bucks that i picked up from the stealership. The mirror is held on by a couple alligator clips and just pops out, then with new mirror its just pops right back in a snap.
This would have been the mirror i would have bought if i had to pay for it.
StewTCB
StewTCB
Oly
All I need is the mirror insert. But for some reason I cant find the heat/autodimming insert.
StewTCB
StewTCB
Oly
OK. Thank you! :)
Sho'Tyme
Georgia
Yeah I'm in the same boat needing a insert for my driver mirror with turn signal ...
StewTCB
StewTCB
Oly
What's funny is I installed a non dimming mirror replacement and the chassis wiring had more connections than the mirror. Coincidentally my rear defroster quit working. I'm hoping that installing the correct replacement all plugged in will magically restore function to the rear defrost. Fingers crossed...
StewTCB
StewTCB
Oly
Thanks 02 Burb! Mirror showed up today and was exactly what I needed.
CHUBBFRESH
Will this mirror fit an 02 suburban??
Mazzmanian
