02 Taho LS with 252K miles.
past few months, i have been suffered from squeeking noise from driver side front suspension.
it gets worse when cool/cold weather.
it squeeks in harmony with body/chassis up/down movement.
even i can make noice by stepping on side step repeatedly.
(only when wheel is straight. when turned, no noise by stepping)
i haven't got time to lift the front but when i wiggle front wheel while it is on ground, there is noticeable click/squick noise.
thinking ball joint is bad.
but how bad is critically bad? safety concern?
i might plan to replace whole upper control arm since it would be little pricey but easier/faster to do it?
from rockauto, found this"heavy-duty" but mevotech's reputation is not that great, i guess.
https://www.rockauto.com/en/moreinf...80361&jsn=486&jsn=486&jsn=486&jsn=486&jsn=486
what you guys thinking about this upper control arm?
and would it be OK if i just do it on driver side?
(passenger side bushings don't look good either but at least it is not making noise.
