My cousin just recently acquired a 2002 Tahoe 5.3 with about 240k miles on it. SES light was on and was showing P0300 random/multiple misfire. I cleared the code and started the engine to see if/when it came back on. After a few minutes at idle the SES came on flashing. I shut it down and checked the code. This time it was P0304, cylinder 4 misfire. The spark plugs looked like they were replaced recently and all looked the same. We swapped the cylinder 4 spark plug, coil pack, coil-plug lead wire, and injector with the other know firing cylinders. Clearing the code and restarting after each swap showed the P0304 code each time. We decided to do a compression check next. Cylinder 4 was 175 psi while cylinder 2 was 180 psi and cylinder 1 was 175 psi. Wondering if it was a possible intake leak, I sprayed some carb cleaner around the #4 intake tract but the idle didn't change at all. I might mention that the cats have been removed by the previous owner. I figured that was the cause for the P0300 code, but when it came to just a single cylinder it didn't make sense anymore.
I did some searching around here and found people solving their issues with injectors and coil packs, but that doesn't seem to be the problem here. At this point I am out of ideas and any help would be appreciated.
