03 - Adding an amp to bose amp
David Paul
Central NJ
Run your new sub amp off the Pioneer's subwoofer RCA output. You don't want a line converter, that's only for when you don't have a subwoofer output. And yes, run main power for the amp from the battery with a fuse at the battery , ground it well, and your Pioneer has a remote turn-on output wire to turn the amp on. You can leave the rest of your system as is. Your Pioneer has full control of the new subs and amp if you do it this way.
Red is spot on with this. This is how I wired my system but with Alpine components. I'm very happy with the set up.
D
dcompton02
Everything ended up working out perfect, those subs hit really hard. I'm gonna have to get a smaller box to fit in behind the third row though. Thank you for the help!
Papaskip
