04 tahoe z71..Grinding noise
Joe Chapman
Alright so, I have a 04 tahoe z71. I have all gears except for reverse and a loud grinding noise in reverse. It's the exact same when I switch it from 2 hi to 4hi and 4lo. Its electronic transfer case. Last time I moved it I'm pretty sure I could push it in park and it made a loud clicking noise. Pretty sure the grinding noise is coming from the transfer case. Can someone help? Thanks in advance!
mijohnst
I'd put all 4 tires up off the ground and see if I could isolate where the sound is coming from. While it's up, try turning the front driveshaft with your hands and see if you can hear any clunking when you do.
pickegs
