04 yukon cigarette lighter plugs always power on , fix to alternative power acc
denalliworld
04 yukon
does every one else have this problem?
I want my cigarette plugs to turn off when the key is out.
does any 1 know how to change the wire to ACC wiring instead of always on for these cigarette plugs
mazdawg(Mikey)
HGIC(head ginger in charge)
Lancaster SC
They come from the factory like that. To change to acc you would need to run a fused wire from the ignition harness to the back of the outlet
ezdaar
Chat Troll
Redneck central, Aka Houston
Install a relay behind the panel. Trigger the relay with acc line or tap into the switched power for radio.
Like that only time cig lighter will have power is when key is on and relay is energized.
Simple and easy.
treehan77
TYF Fiend
Crestview, FL
Wow I've see. Plenty of people with foreign cars want this on when the car is off, but this is the first I've heard someone wanting the opposite
02 Burb
California
I agree but it comes in handy when connecting radar detectors, dash cameras, bluetooth audio devices and so on that use powering on/off to auto connect and start automatically at ignition.
Maic
15 Suburban LT / z71
Houston, TX
Simple and easy.
x2
Mpriest
