04 Yukon Denali Suspension
AkSnipe38
I have a 2004 Denali and the whole air sus is pretty much the sucks. I'd like to convert it and be rid of the whole thing. I've looked up suspension kits online and a lot of them say (Exclude Denali). what good lifts are out there that would bolt right up. I don't wanna go more than 3 inches. Also right now I have a set of Falken Rocky Mountain 2s stock size but I'd like to go bigger and better. Any help would be appreciated. Thanks dudeys
TheAutumnWind
So you want to lift and delete air ride. Ok.
Everything says Excludes denali because it doesn't work with air ride, which is fine because you don't want it.
This member just did that:
http://www.tahoeyukonforum.com/forum/showthread.php?t=69900
http://www.tahoeyukonforum.com/forum/showthread.php?t=69069
I'm about to pull the trigger on all my parts right now on amazon, but first, I just wanted to make sure I'm getting the right shocks. I'm getting the
Bilstein (24-186643) 5100 Series Shock Absorber (for fronts)
Bilstein 24-187237 Rear Shock for GM Tahoe/Avalanche (rears, duh)
these are the correct shocks for the lifting 2"
You can do a keys and spacer lift for ~2.5"
Pull a relay for the autoride compressor and attach resistors to the sensors so as to not get the Service Autoride message.
I am doing something similar, maybe just cranked stock keys and smaller rear spacer with less tire on mine whenever I get around to it.
Jongrreat
