07 Chevy Tahoe LTZ Fuse Block Problem??
AndieAnderson
Virginia Beach, VA
I originally posted a problem with my headlights staying on, checked the switch, it works as advertised, replaced the relay, it's doing it's job, but now I'm thinking the issue is on the actual fuse block that the relay plugs into.
It seems like the problem is resolved until I, A. snap the cover back on the fuse block, or B. hit a bump while driving and the headlight problem returns.
If I unseat the fuse block panel and reinstall, the issue goes away
Anyone out there had similar issues? I'm trying to see if I need to replace the fuse block panel or if there is another remedy that I can try out first.
Thanks again!!!
mikoz
