RAPID
- Joined
- Feb 18, 2019
- Posts
- 5
- Reaction score
- 2
I have a 2007 Yukon Denali AWD. It has high miles and Ive been restoring it over the last few months replacing all suspension, brakes and cosmetics so it can run another 200K. (So selling it to buy a hard to find 2WD is not an option). Its currently AWD but I am moving to Florida and use it for alot of highway miles and towing which does not require AWD. Currently it needs a front axle, AWD transfer case and front differential is getting noisy. Id like to swap out the AWD transmission to a 2WD transmission and eliminate all the weight and rotating mass up front. Curious if anyone has done this exact swap and if any part numbers are available for the transmission, transmission mount and rear driveshaft ect. I realize the transmission will need to be tuned and reprogrammed and its alot of work but I can do most of it myself and dont mind spending the money. Just want to confirm it will physically fit and there are no wiring challenges or anything I have not thought of....Thanks!!!
