07 Denali... No low beam headlights
dougywarren
Just got to my parents for Thanksgiving, 7 hour drive. Get ready to head out for the evening and no headlights. They won't turn on when I unlock or lock, or when I manually turn them on. Brights work so the bulbs work, nothing else seems to be a problem.
Anyone had this issue? relay? either way, I'm driving my mom's VW and I already miss my Denali and I'm embarrassed. first time I was going to show it to my home town friends.
Ugh.....
Hopefully it's an easy fix.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Check your bulbs? They are the 2 in one bulbs correct? Try replacing one and see if it works
Jonah52
Senor ******
Cleveland
Check fuses and bulbs like SUMO said. check your harness connections too.
dougywarren
dougywarren
Relay and fuses are good. Being Thanksgiving I didn't go out and swap bulbs, but my guess is they're both fine. High beams work and the chances of both low beams going out at the exact same time is strange.
sumo
rhode island
But not impossible. Working at a dealership, seen this happen more than a few times. Also do you have hid? Have you checked your sockets? May have melted harness from heat from aftermarket bulbs or hids
dougywarren
dougywarren
Turns out both bulbs were burnt out. Forgot to respond to this. But how weird is that. Never in my life have I ever experience that personally, or with anyone I knew.
sumo
rhode island
Working in. Dealship, I seen this happen a few times.
cpederson
