07 LTZ..Never hear air compressor run and have service supension message
99ls1z
On my 07 LTZ I've been getting a service suspension message pretty much everytime I start up the truck. The ride height looks fine all around and doesn't ride bad. I have noticed that the air compressor never runs anymore to where use to it would start up for a few seconds after the truck had been sitting for a while. I have read many post about replacing shocks, sensors, compressor, etc. and taking to dealer to get a scan run. I'm thinking that the compressor has to be bad since it never runs? Would a sensor or anything cause it not run? Just wanting to fix myself without taking to dealer
ulakovic22
Lantana, TX
The compressors are known to fail, but check the fuse first and run a jumper wire to see if it kicks on at all. If not then you know it's the compressor and you can buy a dorman unit to replace it.
tony97218
