07' Tahoe AC/Recycle air problems
justcallmejoe
I have a 07' Tahoe and the AC will not work. I push the AC button at the climate control and it flashes 3 times and goes dark. Zero function. The same goes for the recycle air button. Push it, it blinks 3 times and goes dark.
I have a feeling this is an ambient temp sensor problem. I have located the sensor outside of the truck behind the front grill. I plan on swapping out the sensor. Cheap part and easy fix. Figured this would be the best place to start.
That said...I have read a few times online that there may be interior sensors that could be causing the problem. Does the 07' Tahoe have a sensor in the rear view mirror? If so this is likely the problem. I bought my Tahoe last fall and when I did I asked the dealer to fix the in dash reverse backup screen. It wasn't working at all. The dealer replaced the rearview mirror and added a small rear camera. The camera links directly to the mirror and the mirror has its own video screen in it. Now before the mirror swap im am pretty positive that the AC was working fine. Ive had no reason to have AC on again until now so it's hard to tell if the problem is definitely linked to the mirror swap or not.
Any tips or info on getting this straightened out would be appreciated. If this problem is linked to the rear view mirror swap is there any way to bypass the ambient temp sensors altogether?
Thanks!
NathanJax
Vacation Nathan
Administrator
Jax, Fl
http://www.tahoeyukonforum.com/threads/a-c-light-blinks-3-times-and-wont-engage-or-turn-on.81009/
or
#07-01-38-006: Information for Vehicles with HVAC Control Module A/C Indicator Blinking Due to Low Battery State of Charge - (Aug 20, 2007)
Subject: Information For Vehicles with HVAC Control Module A/C Indicator Blinking Due to Low Battery State of Charge
Models: 2007-2008 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007-2008 GMC Sierra, Yukon, Yukon XL
with Manual Temperature Control HVAC System (RPO CJ3)
An Air Condition (A/C) button on the Heating, Ventilation and Air Conditioning (HVAC) control module may blink when the A/C system is activated. The blinking indicator will turn to a solid light after cycling the A/C button or ignition key.
This condition may be caused by a low battery state of charge on a PREVIOUS ignition key cycle. This condition may be due to situations were an unsold vehicle is parked for long periods of time as part of a dealership's unsold inventory. The A/C indicator begins to flash If the battery voltage falls below 9.5 volts. The low voltage condition may occur during an engine crank or if the vehicle is parked and a normal battery state of charge is not maintained.
Run the vehicle to charge the battery or connect a battery charger. (If the charging system is operating as designed , the battery surface charge should indicate 12+ volts.)
Do Not Replace the battery, HVAC control module or ECM.
If the A/C indicator continues to blink, use the Tech 2® to help determine the cause.
• Connect the Tech 2 and build the vehicle.
• Select Powertrain.
• Select Engine Control Module (ECM).
• Select Data Display.
• Select Cooling/HVAC data.
• Make sure that there has been an A/C request signal.
• History should indicate any causes.
If necessary, refer to SI for further information on HVAC system diagnostic procedures.
or
#07-01-38-003: Information for Vehicles with HVAC Control Module A/C and Recirculation Indicators Flashing
Subject: Information for Vehicles with HVAC Control Module A/C And Recirculation Indicators Flashing
Models: 2008 Buick Enclave
2007-2008 Cadillac Escalade Models
2006-2007 Chevrolet Monte Carlo
2006-2008 Chevrolet Impala
2007-2008 Chevrolet Avalanche, Equinox, Silverado, Suburban, Tahoe
2007-2008 GMC Acadia, Sierra, Yukon Models
2007-2008 Pontiac Torrent
2008 HUMMER H2
2007-2008 Saturn OUTLOOK
2008 Saturn VUE
Condition/Concern
Some customers may comment that the Air Conditioning (A/C) indicator on the Heating Ventilation and Air Conditioning (HVAC) Control Module flashes then turns off after they press the A/C button. Others may comment that the Recirculation indicator on the HVAC Control Module flashes then turns off after they press the Recirculation button.
This is normal operation for the HVAC Control Module and indicates that the A/C or Recirculation function is not available at this time.
Reasons that the A/C may not be available (calibrated values vary by program) are listed below. Consult the appropriate vehicle Service Information (SI) for detailed HVAC Description and Operation:
• Ambient Air Temperature is too low (if equipped with Ambient Air Temperature Sensor)
• Vehicle voltage less than 9.5 volts
• Refrigerant Pressure too low
• Refrigerant Pressure too high
• Engine Coolant Temperature too high
• Engine is not in RUN
• HVAC Control Head is in the OFF position
Reasons Recirculation may not be available: Mode switch in Floor, Defog or Defrost mode.
The reason(s) A/C is currently disabled can be viewed with a Tech 2® by navigating to HVAC Data display and viewing the "A/C Permission" parameter.
Recommendation/Instructions
Do not replace the HVAC Control Module for a flashing A/C Indicator or flashing Recirculation Indicator, as this is normal operation.
chevyeddie
