BSarteSr
- Joined
- May 2, 2010
- Posts
- 211
- Reaction score
- 46
I do my own brakes, not hard, but found some issues with my '07 Yukon XL Denali.
Truck has 105k miles on it and just recently did the rotors and brakes for the second time since I have had it. First time I found that the passenger side rear brake seemed to wear faster than the driver side or the front. Replaced the rotors and pads all around with good premium rotors and ceramic pads, seemed to work fine.
When the brakes needed to be done again, did the same thing, only I found that the front brakes did not need to be done as soon as the back brakes, so I did the back ones, drove another 10k-12k miles, then did the front. Also found that the passenger side rear wore faster than the others.
Now I have 15k miles on the rear and starting to sound like the passenger rear is needing to be done again (typical grinding sound like the pad wore out), starting to think I have an issue with the rear proportioning valve or maybe the caliper?
My question here is this any kind of a "known" issue or am I just having a typical brake issue and need to troubleshoot a possible problem with the proportioning valve or maybe a caliper?
