09 Yukon starter dragging
skipbrack
Savannah, GA
I bought it a month ago. There is a slight pause after the first engagement of the starter then it continues like normal. I know the previous owners and they took it to 3 places last summer checking it out and concluded it is normal function. To me it sounds like the starter us dragging a bit. The battery is good. Takes a charge from the plug in charger. Alt puts out plenty of volts and the fuel is fine. 92k miles on 5.3. Does anyone else's do this?
BRUTUS_T_HOG
Not normal. What do to mean by slight pause? It engages then stops and starts again?
S
skipbrack
Savannah, GA
Typing the sound out... crank. Craaaaank. Crank crank. Then it runs. This is turning the key and holding it once. Takes about 1 full second to start up. It's not horrible. Just not normal.
Sent from my SCH-I605 using Tapatalk
BRUTUS_T_HOG
Is it ok after the first start? Kind of sounds like coolant leaking into one of the cylinders
S
skipbrack
Savannah, GA
Yes. Always starts right up. Just that little quarter second drag.
Goodinblack
I Like Tacos
Dirty South
I have heard this before on the older 5.7s.
Never knew what caused it though
GM Customer Service
Michigan
skipbrack,
Hello! I understand that you are seeking advice about your vehicle. I might not be able to give you any technical advice but if your concerns lean you to a visit at a dealership, I would be happy to make that process as easy as possible. Please private message me if I can be of any assistance.
Jennifer T.
GM Customer Care
daddyoh
