0W-20 to 0W-40?
jyi786
Given that there is a massive recall on the L87 engine, GM has been informing customers that have had their engines replaced to change their oil every 3,000 miles, and switch to 0W-40.
I've been changing oil every 5,000 miles on my 2019 Escalade, which has the L86, with the factory 0W-20. It still has the AFM, and running strong for 150K miles. Any advantage in switching to 0W-40? I'm already going to be getting a BTDieselworks Autosync to disable AFM.
Marky Dissod
For seriously cold winters I'd recommend 0W30 or 0W40.
For the rest of the year 5W30 or 5W40.
Select motor oils that are recommended for GM's L8T 6.6L gas V8, and/or the 'vette.
Geotrash
Dave
Richmond, VA
Given that there is a massive recall on the L87 engine, GM has been informing customers that have had their engines replaced to change their oil every 3,000 miles, and switch to 10W-40.
I've been changing oil every 5,000 miles on my 2019 Escalade, which has the L86. It still has the AFM, and running strong for 150K miles. Any advantage in switching to 10W-40? I'm already going to be getting a BTDieselworks Autosync to disable AFM.
I think the factory spec oil is 0W-20, yes? On the earlier 6.2's like mine it was 5w-30 and as far as I know the main, rod and cam bearing clearance specs haven't changed between the LS and LT motors.
Some guys here, including me, run 5W-40 Euro-spec oil in their 6.2's. I changed to it on the recommendation of a cam designer when I did my cam swap in my 2012. So far, so good, and I have put maybe 25K on it since then - with many of those towing heavy in the hot summer. That said, I still run the 5W-30 DexOS oil in my unmodified 2007 6.2.
GMCChevy
You mean 0W-40?
It looks like you've been doing good with what you're already doing and a year that still had good engines.
J
jyi786
Yeah my bad: 0W-40. Gonna update the OP so no one is confused.
J
jyi786
You mean 0W-40?
Oh gotcha. I guess this is the keyword: L86 vs. L87. L87 is the one that was recalled.
So L86 is considered "good"? In that it won't catastrophically fail for no reason like the L87?
dcobbs17
