12 volt
boomboom baker
Tennessee
Where is a good 12 volt switched at the fuses that will come on and off with the switch in a 2001 Tahoe
13yukon
Pin #7 in the power distribution block near brake pedal ( second empty socket up from bottom left) must use relay. 1/8 spade terminal I believe. Again mush use relay
13yukon
Pin #7 in the power distribution block near brake pedal ( second empty socket up from bottom left) must use relay. 1/8 spade terminal I believe. Again must use relay
My bad. Didn't even look that you said 2001
bluefox1221
